Hi just click on link it may help you
All best Clive
https://help.brother-usa.com/app/answers/detail/a_id/156744/~/unable-to-print-49
SOURCE: brother mfc465-cn unable to init 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
SOURCE: Brother DCP-385C is not printing the menu on
That error code tells us that the cleaning assembly can't move up and down properly. You need to unplug machine when the carriage is in the center, look over on the right side where the printhead parks to see if there is a paper scrap, clip, or something there stopping the cleaning unit.
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
