Just email me all your issue
[email protected]
SOURCE: Landcruiser KZJ95W engine problem
hi, better check the TCV (timing control valve) located below the injection pump.
SOURCE: Error E559 on air conditionner Samsung MH026FWEA
Go to your outside unit and press the K3 button.
SOURCE: Help with toyota corolla 2003 code P0420
CODE PO420 CATALTYLIC CONVERTER SYSTEM FAULT.ITS SAYING FAULTY CATALTYLIC CONVERTER.IF IT BEEN A WHILE IF YOUR CAR HAS A WHOLE LOT OF MILES ON IT.YOUR SPARK PLUG CHANGE IS DUE AT 120000 MILES. DUE A LITTLE TUNE UP CHANGE AIR FILTER AND FUEL FILTER.SEE IF YOU HAVE ANY ENGINE FAULTS BAD PLUGS DIRTY INJECTORS ANY THING UP SET FUEL SYSTEM CAUSE CAR TO RUN RICH.EXCESSIVE UNBURN FUEL WILL GATHER IN CATALYTIC CONVERTER CAUSE IT TO BURN OUT.SHORTING LIFE OF THE CATALYTIC CONVERTER.
SOURCE: Gree air conditioning unit turns itself off and
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
