Dryers Logo
J
John convery Posted on Jan 19, 2019
Error code E15 on a hoover infinity condenser dryer DYC 890NB, switched off and unplugged for 5, restarted with an empty drum, spun ok but cold for approx 5 minutes then error code appeared again.
5 Related Answers
A
Anonymous
  • Posted on May 07, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Anonymous
  • Posted on Jan 05, 2009
SOURCE: Hoover nextra mega load 7.5kg
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Anonymous
  • 413 Answers
  • Posted on May 12, 2009
SOURCE: My photosmart c5180 gives me the error code
The kind of error you are getting is due to fault in the ink and print section so you can clean the print head with soft tissue and install the cartridge properly and check the vent of it and now reset the printer by turning on and disconnecting by pressing power button for 20 seconds
and hopefully everything will work out it the problem persists then you might have to replace the print head
Thanks And Regards
Anonymous
  • 228 Answers
  • Posted on Jul 22, 2009
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 25, 2009
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
My tumble dryer keeps stopping and showing E15 in the middle of a cycle I've cleaned the air filter it's hoover 8kg
E 15 is an error message. Turn the machine off from the socket. Unplug it. Change the cycle to a different start point. It may have a worn bearing because of overweight and resists the weighthe bearing because of damage. The weight is important to regular functions.
I keep getting E15 Error code on my Hoover Tumble dryer flashing. The dryer is working, but heat is cold.
Control board fault. See... https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-e15-error-on-a-hoover-washing-machine
1helpful
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
2helpful
2answers
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
1helpful
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
2helpful
2answers
Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Top Hoover Dryers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
