Sensor error may be
A peg on the door goes through a hole and pushes a switch. Either peg broke off, push switch not working or sometimes the door comes unhinged at the back on the bottom, the plate with the hole needs bending back up or if peg broke, a screw needs putting up through it from below.
Door switch not working
SOURCE: Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
SOURCE: "Door open" message
Door open could be either the front door, or the top
cover. Both have an actuator for the switch.. A pinched wire could also
be your problem.
That failure to feed out might be your feed rollers and separation pads .. need cleaning.
especially since you've had to tear down.
I clean them with plain water, and blow them dry.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
