Hello Setup codes for RCA TV are given here. Try with them, and get the proper code, y which you can get more functions to operate with: Three digit codes for RCA TV are: 000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194 Four digit codes are: 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Five digit codes with RCA RCR 312W remote control are: 10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
Mats Electronics has Remotes 1-800-628-1118 or you can go to the Dollar Store and Buy the RCA 4 in 1 Remote with Code Book Most Common Code for RCA is 000 $6.00
Retrevo.com has Manuals
hot-replace and solder all leads to smt transformer.set should power up.also flyback may have shorted.rca has a repair kit for this set. all necessary parts.
Question? Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on. Answer: The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A: Select the GUIDE Plus+™ Menu from the Main menu. Select Setup. Select Options. Select Off.
Option B: Select the GUIDE Plus+™ Menu from the Main menu. Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu. Select Off.
Option C: Press GUIDE on your remote control. Select the Menu bar. Press the right arrow button to select Setup. Choose Review Options. Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Go to this link;
http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB
and a short way down under "Product Details" there is a link to the product manual
page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know.
Please post again if you still have trouble;
Hope it helps :)
