Cannot contact make or receive calls.
SOURCE: i have accidentally block one
Just follow these steps
Menu>Settings>Applications>Message>General Settings>Block messages
Delete the contact in that list.
If you're not referring to this, go to Menu>Settings>Call>All Calls>Auto reject>Reject List
Then delete that contact in that list.
Hope this helps. <3
SOURCE: hello i have samsung champ. i
Hope this helps. <3
SOURCE: I accidentally Block messager by
You can unblock in the message settings. For my phone, (S8500 Wave);
settings->applications->messages->general settings->block message
and select delete, then select the number you want to unblock and select delete again.
Might be slightly different process for different phones though.
SOURCE: i have accidentally blocked a
Hi To unblock the accidentally blocked number you need to do the following Press the MENU key Select MESSAGING Scroll down the list and select SETTINGS Select TEXT MESSAGE Select BLOCK NUMBER Highlight the number you wish to unblock and select OPTIONS Select DELETE Select either DELETED SELECTED or DELETE ALL and press OK Briefly press on the ON/OFF button to return to the Main Screen
Testimonial: "Thanks very much, worked perfectly. "
SOURCE: i accidentally block some of my contacts on my samsung corby2 can u help me to unblock
Have you been try the Coolmuster Data Recovery software? This software can help you recover your Samsung phone contacts at ease, you can have a try.
Read more: http://www.coolmuster.com/android/recover-photos-videos-from-galaxy-nexus.html
