Nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
I had the same problem, replaced the pressure switch (right hand side), all ok. BUT, Dishlex has changed the hose size on the switch to a much smaller size. Muck about to change hose size.
Hello misi340 - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful, then the unit could possibly be experiencing a communication error with the control board or wiring failure which only a professional can help with.
