SOURCE: Hi How I Can Download Graphic Card Driver (PCI) Free
by using the mouse and the left clicker on it ; ) here you go: (sis6215) http://www.driverfiles.net/Video-Adapters/SiS-Corporation/page,level2,887,5,resultpage1.html (iv scanned the download (+mirror) its safe) good luck.
SOURCE: video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
SOURCE: installation of graphics card in intel dg31 gl desktop board.
u can...
if u can open the machine...look for slots on the motherboard it's called PCI slots...the slot will be in white/cream color....very close to those PCI slots the cabinet will have perforated opening on it so the PCI graphics cards output slots can face the outside of the cabinet box....
SOURCE: I have a Gigabyte GA-81945GZME-RH
The motherboard has a PCI-E slot, so the Radeon card will fit. You might need to upgrade your power supply, as a 400-watt supply is recommended on AMD's site for this card. Otherwise you shouldn't have any problems with the new card.
Testimonial: "Thanks for getting back so quickly, from what I found out I was pretty sure it would be OK, just wanted another opinion, thanks again "
