Tablets & eReaders Logo
W
Willie Howard Posted on Jan 24, 2019
I can not view my camerias on my I-pad. all I get is the swan badge.
Dawid H Abdullah
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 21, 2019
Dawid H Abdullah
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
134
Points
You probably got SwanView App installed on your device that is trying to override your default Camera. If you do, remove the App and use default iOS Camera. Hope this will help!
~~~Good Luck~~~
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
I have 1400 emails on my ipad I need to delete quickly.
In mail, when you are in a specific mailbox, on the top right side of the left hand column (in portrait view) next to "inbox" press "edit". Then in the bottom left corner there is a "mark all" option. You can do that and the unselect what you want to keep.
The other option, if you don't like those red numbers over the mail app is to follow these directions:
settings > notifications center > mail > select the desired mail account if you have more than one and then turn off "badge app icon"
this works for any app that has those (sometimes annoying) red icons. If you don't want that large number of unread emails on your mail app, use this method. If you want to delete them, use the previous suggestion.
Hope this helps!
iPad 3- iOS 7.1.2
iPhone 5S- iOS 7.1.2
iMac 21.5"- late 2013
My view pad 7 keeps restarting
Take a look at this..Found it with a search..You can try it.but like they say, no guarantees..try at your own risk http://www.addictivetips.com/mobile/how-to-root-viewsonic-viewpad-7-android-tablet-with-superoneclick/
1helpful
How do I EDIT my contacts on iPad2
My contact list is working fine for edits and pics. The difference is that i am only syncing to my phone and computer, not the external google list. In the sync process, is one 'place' designated as the overriding winner when there is a conflict? It may be that it is viewing your pad contact list as a slave, sort of a view only position. Check you settings.
How do I edit contacts on Skype
Sync only to your phone and computer, not the external google list. In the sync process, is one 'place' designated as the overriding winner when there is a conflict? It may be that it is viewing your pad contact list as a slave, sort of a view only position. Check you settings.
I Pad 2 - how to delete picture from a folder?
tap on the picture in question to view it, there should be a trash can on the bottom bar, just tap it and youre done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
1helpful
3answers
Delete photos from tel7j tablet
Go to Photo Browser, rather than tap to view; Touch and Hold until delete option appears.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
