Question about Building Materials
My 1/2 hp craftsman door opener has been working fine. Today it won't stay closed. There is nothing in front of the sensor. The door goes all the way down, hesitates and goes right back up.
I've tried adjusting the travel up and down screws to no avail. The opener is about 18 years old. Any suggestions?
    Habit-Forming:
  • 73 Answers
Although nothing is in the way of the break-beam sensors, are they still properly aligned? They usually have a light on them to indicate if alignment is still correct.
It could be a limiter switch, Although you have adjusted your travel screws maybe the sensor for the downward travel screw is failing?
Posted on Jan 25, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: door opens and then closes wright away
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Posted on Feb 28, 2009
Anonymous
SOURCE: Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Posted on Mar 03, 2009
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
Posted on May 25, 2009
Anonymous
  • 22 Answers
SOURCE: my craftsman 1/2 hp garage door starts to close and then opens up
I had a simular issue, except mine was that the previous owner decided to mess with all the settings and mounts and screwed everything up.
The problem isn't your force sensors its your downwards stopping sensor on the opposite side of the opener. For me I had to take the entire panel off and replace the sensor back in its holder, but try adjusting that sensor setting (clockwise goes down, counterclockwise goes up).
If that doesn't work then i dunno:)
Also set both force settings in between 0-1, for some reason with mine if i set it higher it would set them off....
Posted on Jul 19, 2009
Don Maggard
  • 3197 Answers
SOURCE: garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Posted on Jan 08, 2010
I have a Craftsman 1/2 HP garage door opener, the left sensor is orange and the right sensor is green. the problem is that when i try to open the door, it only opens about a half foot and stays there. i...
Nothing wrong with the sensors and they only work when the door is closing anyway. Sounds like you may have a broken door spring or a bad drive gear. The drive gear is white nylon and is in front of the motor. It will be obvious if it is going bad.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a sears Craftsman 1/2 HP garage door that was working fine,all of a sudden when I close the door,using the wireless remote, the door goes down to about 12 inches off the ground then pops back up as...
If when the door reverses the main light flashes 10 times it is a door sensor problem. Make sure the small light on each one is lit and not flickering. Tweak them a bit. If you can't get both lights to come on you have either bad wiring to the sensor or the sensors are bad.
Mar 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door opener opens fine. When I try to close it the door starts to close, stops, the light flashes and it goes back up. I replaced the two sensors thinking one must be burned out. Before...
Make sure the sensors are wired correctly. The solid white wire from each sensor goes to terminal #2 and the wires with the black stripe go to terminal #3.
Each of the sensors has a small light that must be on for them to work properly. There is a possibility you could have a bad wire. Check to make sure something like a staple hasn't cut the wire.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage door starts to close and then opens up
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman door opener will not stay down
the sensor should shut door off whrn it reaches the closed position (adjust the shut off arm!
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
109 people viewed this question
Top Building Materials Experts
Lawrence Oravetz
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
