SOURCE: Digital Samsung SL202 Camera does
The problem as you can see is lens related. You are gonna have to do this to try and push the lens in. First up remove the battery and hold for a minute. Put it back in and when you hear the camera powering up, help push the lens in, gently. Most of the times, the obstruction is nothing more than tiny particles of dust in the lens gears and you can clear it with little force. If it does not go inside, then we are looking at a much more serious mechanical obstruction and its time for a call to samsung's service center. If you are in the US contact 1-800-SAMSUNG (1-800-726-7864) for shipping instructions. If you are located outside the US, then let me know and I will get you the contact info for your country/region.
Sai.
SOURCE: Just purchased a Samsung PL210
Hi, Samsung includes a disk that has the instruction manual on it instead of a paper one in order to save on paper. If you've lost the disk here's a link to the instruction manual online: http://www.scribd.com/doc/52736239/Samsung-Camera-PL210-PL211-English-User-Manual
SOURCE: I bought a samsung PL210
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
SOURCE: Need a user manual for
You can download the manual from the manufacturer's web site at
http://www.samsung.com/us/support/downloads/EC-PL210ZBPUUS
SOURCE: Hello, Just wondering where I
I believe these are the same as for the PL150 which cost about $20 on eBay, including shipping. However, I ordered mine from [email protected]. Postage (DHL) is very expensive, the LCD is about $13 or cheaper if you buy 5 or more. However, my problem is how to reconnect the cable! I can't find a way to open the cable connecter. Can the connector be opened - or does one have to force the cable into the connection?
