I am not sure what symptoms would indicate bad braking.
Does it have trouble shifting from agitate cycle to the spin cycle? That is when the brake activates(between cycles).
Evidently part 22 is the entire brake assembly.
https://www.appliancepartspros.com/03-clutch-brake-parts-for-maytag-la482.html
Thanks for getting back Clyde, It fills, drains, & spins fine. But it won't agitate. I think it is not locking on the push stroke. The motor is running But it won't agitate. Also on the spin, It turns off but doesn't stop the drum. It keeps spinning & slows down very freely. Like the brake isn't working. I think the brake should lock the trans. on the push stroke & It's not. That why the drum is moving around. Trans. is not avail. This unit has a matching dryer & being on Soc. Sec. I can't afford new. I must fix it again. Thanks Again for any advise.
Robert
For the agitating cycle the motor turns one direction then for spin cycle it reverses direction. First take off the main drive pulley to see if it engages the transmission properly. Turning it by hand should reveal if it works or not.https://www.youtube.com/watch?v=QqKN4l4G...
Video demo taking the whole thing apart.https://youtu.be/2cCW6yq35hY
SOURCE: kleen maid washer leaking seals
normally i would replace brake pads $44.tub seal $ 160 belt $55 and pulley assy on gearbox $ 65 its not a hard job but if you have never done one it may be trikky.also make sure the gearbox shaft under the agitator isnt wobbling if it is buy a new machine.
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
SOURCE: Maytag Dishwasher Model MDB7600AWQ
hi there,
please go to www.reliableparts.ca or .com depending on if you are in Canada or the US. you can purchase the parts from them.
SOURCE: Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Thank You Clyde. The videos help a lot for R&R. Let me get it apart & see what's broken.
Robert
