Question about Dryers
Defy tumble dryer: model 252dtd Replaced the thermofuse 3 times.will not stay hot for long Any ideas? The 10mf ac cap tests 2,4mf. is this a cause ?Drum belt tension is good and motor turns free.
Make :defy Model:252dtd
  • kmackay
    kmackay Jan 27, 2019
    thx Brad apreciate the advice.I will replace the cap and thermofuse and monitor.May be I should put a 2amp ac .breaker temporarily in the,circuit instead of thermofuse ,just as a test..to monitor.Cause these thermofuses are not cheap.Only if heating problem is resolved will buy and replace thermofuse.
  • Dryers Master
  • 18,121 Answers
That capacitor does not control the heater. With that in mind, it does control the motor and the motor not spinning at the right speed will cause the air flow to be reduced. This will cause the heating unit to become too hot.
Posted on Jan 26, 2019
  • 459 Answers
Check the exhaust vent for restrictions
Posted on Feb 02, 2019
5 Suggested Answers
6ya staff
SOURCE:
networkmagic
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
Anonymous
  • 236 Answers
SOURCE: Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
ashburton
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
andycutts26
SOURCE: whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Posted on Jan 01, 2011
Defy Tumble Drier DTD 252 wiring diagram
Request the wiring diagram directly from Defy.
Dec 10, 2017 | Dryers
Where do I find the capacitor in a defy tumbledrier model DTD242
Capacitors are used on the motors to add additional starting torque. If your dryer has a cap, it will be on or near the motor. Dryer electrical elements do not have caps: they are resistive.
Oct 22, 2014 | Dryers
White knight tumble dryer cl43
Try the thermofuse it has one connection on either end and is placed where all connections go to
Apr 04, 2014 | General Dryers
My defy tumble dryer is not getting hot just blowing cold air
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Apr 21, 2011 | Dryers
Tumble dryer not getting hot
Likely to be a thermostat or heater element problem.
These are located at the rear of the dryer, behind a removeable cover, but you will need a test meter to check them out.
Hope this helps.
Dec 15, 2009 | Hotpoint Dryers
Maytag dryer runs and tumbles but will not heat up to dry clothes. model # LDG7500AAW, serial # A3351803. it does have flame but will not stay hot. Is this a thermostat problem?
I would suspect a faulty high limit thermostat is causing this problem. It is usually a small round, black device mounted on a small plate and attached to the internal ductwork with two screws. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Jan 18, 2008 | Dryers
Kenmore dryer. 80 series. 6 years old.
There is no reset button on these thermofuses unfortunatly. Sometimes you can have a timer go out and cause a fault in the thermostats, thermofuses, etc. Doesnt happen to often, but it does happen. Be sure before you spend a lot of money, that you thoughly clean and check you dryer vent tubes or pipe. A clogged vent tube will normally cause major league problems (i.e. burned thermofuses, busted elements, out-of-temp thermostats, slow or no drying conditions, etc.). You can replace these yourself pretty easy if you have some hand tools (call Sears to fix and you can buy a new one) and a couple of minutes. Let me know if you want further instructions or help. Good Luck!!!! JIm
Dec 29, 2007 | Dryers
Dryer runs but won't heat up
Is the fuse bown.or is the circuit breaker tripped?
if the fuse is blown or the circuit breaker tripped .the dryer might tumble but not heat.
Dec 28, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
