Question about Maytag MAH2400A Front Load Washer
Our front-loading HE washing machine delivers
Our 1 yr. old, front-loading HE washing machine delivers disgusting, moldy smelling clothes. We have researched and used the following: Clorox, Borax, Baking Soda, Vinegar. We have raised the lip of the seal and cleaned every washing. Still we get strong moldy smell. What more can we do? Thank you Linda Stewart
  • 24 Answers
Try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Posted on Aug 05, 2009
6ya staff
SOURCE:
Bosch Axxis washing machine: clothes small moldy after washing!
Due to mainly running low temp washes and bacteria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe) many machines will begin to smell, generally the smell is described as a damp flannel!. This can be transferred to the wash load if like myself you tend to put a load on before going to work and then removing when you get home. (The washing is clean but smells disgusting!!!)
Run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) If you buy stores own as it is cheaper than miltons. The first time you need to do this, run the cycle twice to be sure it was cleared out.
My machine is six years old and the first smelly signs were when it was about a year old, I do mainly 30 and 40 degree washes with and occasional 60.
I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months.
Hope this helps. Roni.
(ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Sep 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
What does de mean on the display of the washing machine? Yesterday I ran a tub clean because my clothes have been smelling moldy. I have cleaned the rubber seal & leave the door open. Please help??
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Apr 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Why does our duet whirlpol washer smell like mold. Our washer are
Your washer smells moldy because there is mold growing in it somewhere. To kill the mold and clean the inside of your washer do a hot water wash using no clothes but adding two cups of bleach to the machine. It will also smell better then.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Is there ANY way to remove the gasket from a frigidaire GLTF2940ES front load washer???? It is absolutely covered with mold, it is moldy underneath, my clothes smell disgusting!!! I want to clean...
yes there is way
How to remove and replace the drum gasket on the Frigidaire -Front Load Washer with notes on tub bearing replacement and inner drum replacement....
for all the detailed instructions
click the link directly
http://www.applianceaid.com/417_Frigidaire_washer.html
hope this helps
May 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Moldy smell
Hi Jewel,
You may want to try some Washer Magic, or similar product specifically designed to clean out washing machines. I personally use Affresh in my front loader and it works very well.
SG
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Maytag MAH2400A Front Load Washer Logo
333 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
