SOURCE: Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
SOURCE: Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
SOURCE: My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
SOURCE: got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
