SOURCE: my kyocera fs mita 1920 some dose not print or
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
SOURCE: HI there! Our Kyocera 180
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit
and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
SOURCE: I have a kyocera taskalfa 180 and its displaying shake tonner
You can download the full manual from this site, but this page provides your answer to fix the problem: http://www.manualslib.com/manual/485194/Kyocera-Taskalfa-180.html?page=129
The toner has probably settled in one or more cartridges. Just give them a gentle shake and re-install.
