Question about Mackie Audio Players & Recorders
Mackie SRM-150 Power light on but no sound at all.
6ya staff
SOURCE:
mrwtech
Marc Wiggins
  • 59 Answers
SOURCE: I have a pair of
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Posted on Dec 04, 2008
Anonymous
  • 4 Answers
SOURCE: Repair a Mackie SRM 450 Speaker
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Posted on Jul 21, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Hi i have a Mackie srm 150 monitor and have blown
The speaker can be purchased from Mackie directly. Follow the link below to go to the support page and continue from there. I would call them with the specifics of your unit to get the correct replacement driver. It is common for different serial numbered units to use different drivers. They can confirm this when you call. I have dealt with them many times and have found them to be very helpful and prompt for parts delivery.
Dan
Link: http://www.mackie.com/support/index.html
Posted on Mar 02, 2010
Testimonial: "Thanks Dan will contact them "
Anonymous
SOURCE: Mackie SRM-450 tweeter distorts sound
I wish to change access to the diaphragm
Posted on Jun 16, 2010
ABRsvcs
  • 4234 Answers
SOURCE: hello there i have a
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Posted on Jan 12, 2011
My mackie srm 150 has power but no sound
If there's no sound at all then there's a problems with speaker-soundboard connection.
Mar 03, 2015 | Mackie SRM150 Compact Active PA Spkr ea
Mackie srm 450v2 tweeters sound low
You have to disassemble the cabinet with a 18 inch long screwdriver first in order to get access to the driver, then remove the 4 allen nuts on the plastic that covers the diaphragm and proceed to change the diaphragm, most of times they start to sound low because they break the titanium in peaces or in a small portion.
Aug 06, 2013 | Mackie SRM-450 System
Mackie SRM-450 All LEDs on
Some of the +15V/-15V is missing at power supply and this is a good starting point, let me know if i can help you more.
Oct 20, 2011 | Mackie SRM-450 System
Mackie SRM 450 V2 has no power
Have you check the inside fuse?
Oct 02, 2011 | Mackie SRM-450 System
How do I replace the fuse on a Mackie SRM 350 v2?
The fuse is inside and is to be replaced ONLY after you repair the cause of it blowing. Additional damage may result if repair is not made first. Power it up with a 150 watt light in series with the power cord as a resetting fuse. When light remains out, unit should be good.
The fuse is mounted on a circuit board behind the power input connector.
Here is a link to a service manual that is probably close to your unit:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down at the web page to a small link that says "Get Manual" Click on that and after download unzip the file... it is free... ignore the winrar thing...
Apr 01, 2011 | Mackie SRM350V2 POWERED SPEAKER
I'd just order a new diaphragm and see if that's the problem before any other dismantling. If that's not the problem, I'd take it to a certified repair shop. The fact that it's still working but not producing certain frqs,tells me you won't be able to see the problem with the naked eye.
Feb 19, 2010 | Mackie SRM-450 System
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
PickyPrick
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
