Washing Machines Logo
R
Rosemary Ward Posted on Jan 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele NovatronicW310 The drum rocks from side to side and sometimes a loud bang & shifts the whole machine. Replaced 4 shocks or struts with commercial grade ones about 6 years ago. Does it need new?
mpservices
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Miele Expert 191 Answers
  • Posted on Mar 03, 2019
mpservices
Miele Expert
Level 2:
Wolfpack:
Answers
191
Questions
0
Helped
245637
Points
342
Could be a couple things - a spring (there are four of them ) that the drum hangs from could be broken or has come off the mount. Another issue may be the arm that holds the inner drum - it may have corroded and become unstable - we can usually detect this by opening the drain below the drum and empty it into a Tupperware - examine the water and look for small black fragments - they will be hard like metal and about the size of a grain of sand or larger. These are magnesium particles from the arm that supports the inner drum - unfortunately the inner drum would have to be changed if that is the case
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on Aug 29, 2008
SOURCE: Loud banging during kneading
Usually with products like this, one gear will be a plastic instead of metal which under too much stress will shear. Basically to narrow down the problem, you will need to open up the machine and find the part that is worn down considerably and then we can get you to the manufacturer or another retailer that can get you the replacement part
Anonymous
  • 51 Answers
  • Posted on Oct 08, 2008
SOURCE: suspension groans when making a left turn
sometimes the noise is in the steering wheel the plastic is rubbing together causing that sound.
Anonymous
  • 8 Answers
  • Posted on Mar 13, 2009
SOURCE: Banging and loud howling noise at high speed
Drum bearings may have given up.
Anonymous
  • 68 Answers
  • Posted on Apr 26, 2009
SOURCE: loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 27, 2009
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
2answers
Out of balance when spin starts
Hi dear. Your machine needs new shock absorbers and drum tension springs replacement. I can advise to contact your local Miele center. Thanks.
There is a loud bang when coming out of the the wash cycle and starting rinse cycle
check the springs and shock absorbers. It might be the shock absorber (also called a damper I think) has broken or is too loose.
After 23 years of good service the drum has fallen off at one side. Is it worth fixing or buy a new one?
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
My machine was banging loud in te spin cycle and now it fills with water but won't spin or agitate the motor is not coming on
Hello,the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Thanks
7helpful
3answers
Washing machine makes a loud banging noise during cycle and when I check it the machine has changed position (unit is turned slightly sideways) How to correct
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
Regards
Berry
2answers
Tub is banging loudly on spin cycle . machine is leveled
please check the shock obsorbers and replace them if they are not holding the drum.
1helpful
2answers
Machine banging when in fast spin
if the noise is coming from inside the drum then it will be the bear ings if this machine is less than 3years old then this is what bust hotpoint they changed the bearing setup and put a spring on it which its the spring that is the complete failure u need to take the complete drum out strip this put the new bearing set in but without the spring this wil put at least 2-3years on the bearings its a big job and costs about £120 to fix u r accually better off buying a completely different washer no good are hotpoints anymore m8
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
