SOURCE: iphone wont turn on at all help
Have you tried a hard reset? If this doesn't work, have you tried plugging the phone into iTunes to see if you can do a full restore?
Hard reset:
SOURCE: help!
i would go out to Toshiba's web site and download new drivers for it. then i would go into device manager and uninstall the driver for it. after that is done then you install the new driver for the wireless card and hope that it works. it that doesn't than you might have a hardware malfunction or software conflict.
SOURCE: Number 2 In top right hand corner
That doesn't do it...
Physically unplug your cable box for at least one minute. This reboots your digital cable box and the number should be gone. It has nothing to do with your television.
I hope this helps!
SOURCE: Camera wont work.
this is hardware problem not firmware ... not need to master reset or update firmware ... Just check at back of your P1i ... press softly/sense the camera part with your finger if the lense can be shake/unfixed then press softly the upper part of the camera .. the try open the camera application to take a photo shoot ... try & try again ... the bring your camera to service center ... ask to fix the camera position ... have a try ... Regards, Ferdy / Indonesia
SOURCE: no picture
Try booting into safe mode. This will tell you if its your screen resolution setting or hardware failure. Or even remove any software that might have cause it. You can even try booting "last good know startup / configuration" depending on your OS.
