Have a problem with my nec vt 46 projektor, the lamp dosent work! i have checked the manual and according to the troubleshooting i have a "lamp error" where it sais that i should wait a full minute and start the projektor again, nothing happens, it just blinks orange, and when it starts up,ihear a klick or tick sound, like the lamp is trying to fire up or something, please help!!
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
