SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
SOURCE: Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut
the blue wires and discard the reed switch. insulate the ends of the
blue wires and push them back into the track in different directions so
there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9.
Cut the white wires at the contacts, strip 5mm of plastic off the wires
and twist them together, The wires will have corrosion, clean them with
sand paper, they must make good contact. I recommend that you solder
them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
SOURCE: Hi I have a Simpson 8kg washing machine ezi sensor
Those machines with a will of their own can be difficult to handle.
Ask the electician if there could be something wrong while spinning.
kolbrun
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
