Question about Ariens Garden
Is Ariens ST924. 2 stroke or 4 stroke engine?
  • 459 Answers
Should be a 4 stroke
Posted on Feb 02, 2019
Testimonial: "Thank you ????"
2 Suggested Answers
6ya staff
SOURCE:
svtcobra97
SOURCE: Is Ariens ST 270 a
It is a 4 stroke engine made by Tecumseh. It is 2.7 horsepower, but I don't know the model # of the engine itself. Try going to Ariens website. With a little digging around, you should be able to get a manual from them that shows all the parts. Also try finding an Ariens dealer near you. They should be able to find and order parts.
Posted on Dec 12, 2010
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
This id an Ariens 8 hp reasr engine rider
areins RM830e I found some info on Parts tree and Utube for you, take a look Ariens 927025 RM830E Ariens 30 Rear Engine Rider 8hp SN 000101 004000... . If not the right one repost and exclude this model .
Mar 16, 2016 | Ariens Garden
What is Ariens ST 350 engine? A 2 stroke or 4 stroke engine?
It's a four stroke, the engine takes 5w-20 engine oil. Just Google it, there's free manuals online....
http://lawnandgarden.manualsonline.com/manuals/mfg/ariens/932000_series.html
Dec 18, 2014 | Motorcycles
The magnum 20 engine has had the fuel pump cam slide down so the fuel pump no longer works.
The fuel pump works up stroke of piston, building pessure to force fuel to carb. Check your lines going to it. So they are clear.
Feb 23, 2012 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
Is the engine 2 stroke or 4 stroke
Honda engines are traditionally 4 stroke. If the exhaust comes out of the head it is a 4 stroke, if the exhaust comes out of the cylinder it is a two stroke.
Apr 16, 2011 | Honda XR 250 R Motorcycles
Is Ariens ST 270 a 2 stroke or 4 stroke engine?
Nov 19, 2010 | Sport & Outdoor - Others
Unknown Spring on Ariens Walk Behind Mower (1980's)
there is a hole in the top of the governer it goes in there
Jun 23, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Garden Logo
64 people viewed this question
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Thomas F. Schneider
Are you an Ariens Garden Expert? Answer questions, earn points and help others
