Televison & Video Logo
B
Breanca Posted on Feb 03, 2019
I factory reset my Toshiba fire tv and it will not recognize my amazon remote
The remote does work with my fire stick but the tv will no longer recognize it
Gabriel Zamora Paez
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 16, 2019
Gabriel Zamora Paez
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
4854
Points
35
Reinici? la f?brica de mi Toshiba TV de fuego y no reconocer? el control remoto de Amazon
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 18, 2009
SOURCE: Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Anonymous
  • Posted on May 12, 2009
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Anonymous
  • 1015 Answers
  • Posted on Sep 26, 2009
SOURCE: We have 2 Sylvania TV's. The remotes work on one
The tv has a infared remote eye located at the front panel. It is possible that the remote eye sensor has gone bad. You could try cleaning the remote eye lens. There might be debris that got inside the remote eye housing and is blocking the sensor. You could also try installing fresh batteries in the remote.
Christopher Stearns
  • 101 Answers
  • Posted on May 30, 2010
SOURCE: Need to reset the tv/remote on a sony trinitron
ay make sure u press tv on the remote first and the batts in it are good
ronharvey_ll
Ron Harvey
  • 14 Answers
  • Posted on Jun 24, 2015
SOURCE: how do i upgrade soft wear to my amazon fire tv stick
URL for software updates and instructions
Should also be in your user's manual.
http://www.amazon.com/gp/help/customer/display.html/ref=ya_kindle_sb_swupdates?nodeId=200529680
Ron Harvey
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/ron_a476a70a75690d24
3answers
How can I fix the television remote control to access my Amazon Fire Stick please?
Pair Firestick remote to TV
Go to Settings on your Fire TV. Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
Amazon.ca Help: Pair Additional Fire TV Remotes
Videos as well
https://www.google.com/search?q=television+remote+control+to+access+my+Amazon+Fire+Stick
Having problems with my fire stick, can't get live tv anymore. What can I do?
Perhaps do a reboot of your fire stick. It corrupts at time.
Link will show you the process.
How to safely Reboot and Restart the Amazon Fire TV
If that doesn't work...a factory reset may be needed. It will erase everything and return you to say one.
How to Reset Erase your Amazon Firestick to Factory Defaults
The video will show you how.
Good luck.
Semper Fi,
Z
2answers
Ireset my fire stick to factory and now won't work
hi there.
this is all i can find out.
How do I fix my Firestick? Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. problem with the Amazon Fire Stick and the remote.30 Sep 2015
SOLVED: Why won't my Amazon Fire TV remote work ... - iFixit
https://www.ifixit.com/Answers/.../Why+won%27t+my+Amazon+Fire+TV+remote+wor... Search for: How do I fix my Firestick?
or try this link for more help if you need it.
amazon fire stick not turning on Google Search
2answers
Fire stick remote not working
Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. Press the Menu + Left (directional key) + Back buttons at once for 10 seconds. These are the steps for factory resetting of remote.
2answers
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
2answers
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Accidently turned off blue tooth
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
