Dina Massey Posted on Feb 04, 2019
I'd like to know what ribbon and correction tape is needed for the AEG Olympia XL501 electric typewriter. Anyone know?
3 Related Answers
Steven Ford
  • 74 Answers
  • Posted on Jul 26, 2009
SOURCE: Changing the ribbon and correction tape on an IBM Selectric III t
Here is a scan of the manual for your typewriter.
Dick O Reilly
  • 3594 Answers
  • Posted on Oct 08, 2012
SOURCE: need a scm corp electric portable typewriter service manual & ribbon
If your T/W is a cornet and the ribbon slides in from the R. side We have them in stock.
DickyO
216-269-3918
JUSTOLDJIM
James Cagle
  • 482 Answers
  • Posted on Aug 25, 2015
SOURCE: need black typewriter ribbon for Olympia typewriter
I have them in stock
Which typewriter ribbon do I buy
If the spools are 2" in diameter have a 1/8" hole in the center with 4 or 5 smsller holes around it this is a pretty standard fabric ribbon we have them in stock if it is different sem\nd the spools to us and we will wind a new ribbon on them.
DickyO
216-269-3918
1helpful
After pressing correction key i could not type again .no ink is there .
During correction the lift-off tape is raised. Please check that it goes down and does not interfere with the printing ribbon.
Removing and reinstalling both is probably the best way.
Olympia Compact 3, I have the correction tape installed properly but it will not correct
Be sure the dull side of the tape is facing the paper and that the ribbon is correctable a yellow or orange knob.
DickyO
I have an Olympia Standard elec typwriter. Does anyone know where I could find someone (NE London for pref) who could correctly install one of my replacement cartridges and correcting tapes. As it is,...
I think the reason why the tape is no longer rising up is due to the failure of the orange cog at the bottom of the carriage (just under the printer ribbon). This stops the carriage rising.
Can you inspect the cog and check it is intact? Also look at the bottom of the typewriter inside an look for sheared off organge teeth
Let me know if it's that issue and I might be able to give you a solution
The correction feature is not working correctly. It attempts to lift the incorrect the symbol/letter, but fails. There seems to be plenty of correction tape and the ribbon seems to be on correctly ......
Be sure that the ribbon and L/O are fresh. If so be sure the L/o is installed with the dull side toward the paper and be sure the ribbons are correctable. (YELLOW OR ORANGE KNOB)
DickyO
1helpful
I have an Olympia Electronic Compact. When I turn it on, it just beeps very fast. Nothing works? I love this typewriter, please help!!!!
I have the same typewriter. If I remember correctly, beeping very fast means there is a problem with the printer wheel. You might try (with the typewriter off) pulling back the wheel, reinserting the wheel, and turning on the typewriter. If that doesn't work, get another wheel (they're cheap online if you buy a Swintec wheel rather than an Olympia wheel - same goes for ribbons). The only other thing I can think is that the ribbon is out, needs reinserted, or there is no correction tape in the machine. But I think it has something to do with a broken or misplaced wheel.
2answers
Need black typewriter ribbon for Olympia typewriter
A General Ribbon T6 or equivelent will work.
DickyO
Olympia XL501 typewriter does not type letters on keyboard
make sure ribbon and corr. tape are installed correctly
" " nothing is interfering with the free rotation of the printwheel
check to make sure the "pitch" selection matches the printwheel
if these seem ok seek a repair shop
4helpful
2answers
Typewriter change correction tape
I just finished replacing mine..You must first remove the ribbon for the typing, this simply lifts off. Then you must place the side with the corrective tape on the left side and the empty end on the right. While doing so, make sure that the ribbon of corrective tape is being placed around the knobs( one on each side) to hold in place. Then feed through and wind up till all the orange has disappeared then replace the Typing ribbon and this should complete the replacement
Top Olympia Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
NOEL
NOEL
jws1013
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
