SOURCE: DIP switch positions
Found them finally Pete - this is the service manual for the printer; http://www.posguys.com/download/TML90_Peeler_TRG_RevB.pdf Check page 45 of the pdf (page2-21 of the manual) for the location of the switches, the next 2 pages for the settings a bit clearer than on my previous post. also probably worth a read through the rest, in case there are some other possible solutions - I couldn't find one but you might see something that sounds familiar. Hope this helps, still trying to find a user manual direct link, will post it if i find one :)
SOURCE: driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
SOURCE: Can you tell me what
http://www.bluestarinc.com/techsupport/epson/Dip_SW_Settings/Default%20DIP%20SW%20Setting_Rev%20D.pdf
About halfway down.
Also:
http://www.beaglehardware.com/support6000.htm#DIP_Switch_Settings
SOURCE: dip switch settings for Epson
I put the page you need up on my server.
http://www.itrsva.com/TM-U210-DIP_Switches.pdf
Hi darrell801, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Are you sure it is an Epson TM-L90? Also, where do you think the dip switches are supposed to be?
Hi Robert, I am certain that it is an TM-L90. The service manual shows that they are under front cover on right side under little rubber removeable thing.
In the manual you can see the dip switches but when I remove my "Cap" it is empty.
