SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
SOURCE: hunter reversible window fan made in the 50's.
A simple shaded pole non capacitor type diagram is all the same!
the reversing of the hot legs entry is an either or relay with a normally open and nomally closed set of contacts
SOURCE: fan running slowly
It seems that the motor armature is burn or about to burn .
If you
can fix it by yourself , then dissemble the unit, remove the motor.
Loosen the bolts running from end to end of the motor and with emery
cloth, clean the small metal plates on the end of the armature. They
should be bright copper color. If the armature is burnt, they will be
dull brown. The other thing is to replace the brushes in the motor . or
call for repairing if you are not sure that you can do it by yourself .
PLEASE
DON'T FORGET
TO RATE !
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
