SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
SOURCE: i have a maytag neptune front end washer. model #
hi..
First clean out your outlet filter. If this does not work, open up
behind and tighten all points where wires are joined; due to vibrations
these might have come loose. Plug off the wall first!!..
thank u
SOURCE: WATER STANDING IN THE DRUM AFTER WASH CYCLE
can you see water in the tub, or do you hear water when you turn the tub? if you hear water when the tub turns, it is not water. the stainless drum has a liquid inside it for balancing loads. if this is the case, there is no problem. but if you see water in the tub that didnt drain, you need to check the pump and the hose from the pump to the outer tub. look for restrictions (coins, tooth pick, nail, ect.). also check the pump impellers to make sure none of them are broke, there are three plastic impellers. if any are broke, replace the pump. hope this helps you. let me know if you have any further questions. shane
Testimonial: "I appreciate your very comprehensive response to my situation. I have learned that buying that Neptune was probably my biggest mistake :("
