Question about Symbol Computers & Internet
I tryed to upload a new conf to the Symbol DS9808 via the 123Scann - to @. After upload, it works until unplug it from USB- after next connection with PC ,scanner beeps only without scanning...
  • Symbol Master
  • 1,645 Answers
Anonymous
SOURCE:
Anonymous
  • 63 Answers
SOURCE: Scanner not recognized by computer
Try to check control panel>device manager>check if there is an imaging device on the list. If none, it means that the computer is not detecting your printer. Try to plug it in to other port or try to use another usb cable. If still won't work, you need to uninstall and reinstall the drivers for the scanner
Posted on Feb 07, 2008
tommya300
tommya300
  • 724 Answers
SOURCE: Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Posted on Jul 27, 2009
SOURCE: first time connection?
The MC9090 does not require any installation.
All it requires that you have ActiveSync installed on you PC. That can be downloaded directly from Microsoft. got to www.microsoft.com and just seach for activesync.
Just make sure that the MC9090 is configured to comminicate via USB
Settings >> System >> USBConfig
Make sure it is set to [USB Client Mode].
Also
Settings >> Connections >> USB to PC
Make sure that [Enable advanced network functionality] is ticked.
If you need any more help dont hesitate to contact us
www.biastechnology.com
helpdesk@biastechnology.com
Posted on Sep 11, 2009
Eric Sandbo
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
Anonymous
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Posted on Apr 30, 2010
I need to find a card reader for my Fujifilm S2900's media card to USB port for Windows 7.. Where do I look?
This is a great camera. I suggest uploading the photos directly from the camera to the computer via USB cable connection. The software provided by Fuji works well but is not necessary to do an upload.
Keeping the memory in the camera is safer and ultimately more reliable then switching out and back. Static discharge and connector damage can be a problem.
Keeping the photos in memory after transfer until the PC images are confirmed and backed up provides the reliability for priceless photos. After successful transfer and backup I will erase the photos from camera memory card before the next use.
The cable provided has two uses, connection to PC and connection to TV/monitor.
See page 86 and page 60,70 in the link provided of the Fuji manual.
Hope this helps?http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s2900_manual_en.pdf
Oct 31, 2016 | FUJIFILM Cameras
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
Would you please help me with how to set up a conference call?
Conferencing
Make call or when you have answered a call.
On the screen will appear CONF, PAGE, and MUTE
Press left hand soft key that is under CONF
Make next call by dialling 9 plus no. or the extension no.
Once you have the person you wish to speak to connected press CONF twice until you are all connected together.
You can have up to 5 people in a conference, you just repeat the process.
To leave the conference but leave the other parties to carry on (unsupported conference) Press CONF followed by your own extension no. This has to be the extension which started the conference.
Hope that this helps, I have also uploaded a video off http://www.abbeytelecom.com showing how to do conferencing there are loads of others on that site.
Apr 25, 2011 | Samsung Prostar DCS Phone
How to upload files to a mc9090 scanner from a PC
We use a HHT base station that is connected via USB and then use Microsoft ActiveSync software to connect. Once connected you can explore the HHT from the PC and drag and drop to the HHT.
http://download.cnet.com/Microsoft-ActiveSync/3000-2094_4-10031823.html
Jan 21, 2011 | Symbol MC9090 Barcode Scanner
Symbol DS9808 will not scan barcode
Hello Dbird,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for DS9808.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Dec 02, 2010 | Zebra Symbol DS9808 Barcode Scanner...
When I plug in my vehicle power supply into my nuvi 250 gps, the computer symbol appears on the screen and my map will not return until I unplug the power source and turn on and off the gps unit. How do I...
This may be happening if you are connecting the GPS to the vehicle power source via USB cable, instead of the supplied power cord & cradle. If this is the case, try again not using the USB connection method.
Another source for free, comprehensive help is available directly from Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Sep 17, 2009 | Garmin nuvi 250W GPS Receiver
Computer does not recognize coby mp705
you know the hold button on mp3 player? while connected to the computer, move it to the left until it says hold and it stays there... or if its already on hold move it to the right until its stuck on start symbol
or move it to the right and left vs left or right..
it worked after i played with it for a while...
now if you wait 30 seconds it may or may not reappear :o
Jan 06, 2009 | Coby MP-705 Digital Media Player
Computers & Internet Logo
24 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
