Dryers Logo
R
Rob Linneweber Posted on Feb 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Dryer quit working. Like there is no power. Thin Twin LT7000XVNO
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Feb 10, 2019
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017793
Points
74913
Check voltage to dryer, door switch and thermal fuse to begin with.
  • 5 more comments
  • Rob Linneweber
    Rob Linneweber Feb 10, 2019
    Have done that and have continuity to all. Thanks
  • Chris Huff
    Chris Huff Feb 10, 2019
    Did you remove wires from thermal fuse when checking for continuity?
  • Chris Huff
    Is there 240 volts going to dryer?
  • Chris Huff
    Do you hear door switch clicking when manually pressed?
  • Rob Linneweber
    Yes there is 240 volts to dryer. The door switch does click when manually pressed.
  • Rob Linneweber
    Yes I did remove the wires when checking thermal fuse for continuity.
  • Chris Huff
    Chris Huff Feb 11, 2019
    Probably the timer then.
Justin Moore
Level 1:
Habit-Forming:
New Friend:
  • Contributor 6 Answers
  • Posted on Feb 11, 2019
Justin Moore
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
6
Questions
0
Helped
722
Points
14
1st be sure both breakers are on at breaker box, if that doesn't solve the problem, remove back panel and ohm out thermal fuse it's probably flat, white with 3 wires.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Mar 16, 2008
SOURCE: Whirlpool Thin Twin
Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
David Dishong
  • 15 Answers
  • Posted on Mar 19, 2008
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 26, 2008
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Anonymous
  • 1122 Answers
  • Posted on May 28, 2008
SOURCE: Whirlpool Thin Twin YLTE6234DQ2
YOU CAN DO THIS.,POP THE FRONT PANEL OFF,GO TO THE SWITCH PLUG JACK ON RIGHT SIDE UNPLUG JACK,ON THE SWITCH SIDE WIRES CUT THE OUTSIDE WIRES PUT THEM TOGETHER WITH WIRE NUT,LEAVE GREEN WIRE ANONE,PLUG BACK INTO JACK,YOUR DONE,REMEMBER NOW IN THE SPIN CYCLE IT WILL WORK BUT WHEN YOU OPEN THE LIP IT WILL NOT TURN OFF SO KEEP YOUR HANDS OUT OF THERE,THANKS-MIKE
Anonymous
  • 88 Answers
  • Posted on Sep 18, 2008
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Whirlpool thin twin model LT7000XVNO washer won't spin
The pump might need to either be replaced in your washing machine or the pump could be clogged. To check the pump you will have to first disconnect the drain line and then remove the back panel on your washing machine and use a flashlight.
Whirlpool Thin Twin. NOISE WHEN SPINNING.
Noises are difficult to 'hear' in writing. The machine uses two motors, and it would be quite the coincidence if they got dry bearing together.
Here are all your parts in nice exploded diagrams.
https://www.ereplacementparts.com/whirlpool-lte5243dqb-thintwin-washerdryer-combo-combo-parts-c-163752_166067_323771.html
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 • Dryers
3helpful
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4helpful
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
1helpful
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
