Televison & Video Logo
c
carol gunning Posted on Feb 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No tv picture is black around it and does get full picture...it is Westinghouse 32 in hdmi
John Norton
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Feb 10, 2019
John Norton
Expert
Level 2:
New Friend:
Answers
105
Questions
6
Helped
54524
Points
346
Please be more clear what the issue is
5 Related Answers
Anonymous
  • Posted on Jun 10, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Anonymous
  • Posted on Aug 23, 2009
SOURCE: Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Chi Chu
  • 8457 Answers
  • Posted on May 23, 2010
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Chi Chu
  • 8457 Answers
  • Posted on Sep 17, 2010
SOURCE: Westinghouse 32 lcd tv - no picture no sound - set
Reset the tv and the cable or satalite boxes,replug it back an hour later let the tv reset it self back to factory setting and the boxes upgrade it software.The tv should work now.Not,than yes.It the Tuner main board.
Testimonial: "Quick response got me in the right area."
Anonymous
  • Posted on Jan 15, 2011
SOURCE: No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
No picture from dvd when using hdmi cable
make sure tv is on correct source for that hdmi input.
The picture went black, but the tv still has audio
The back light inverter board may have gone out, or ir is not getting 24vdc from the power supply module, check those two places.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w1+
Screen is completely green when using hdmi cables. any solutions or know issues? it is a 32" Westinghouse tv approx 3yrs old
Try a different sorce to the HDMI and see what happens then. If the issue goes away then its either a compatability with the device thats causing the green screen or that device is bad.
1helpful
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
