SOURCE: Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Testimonial: "Thank you. Freezer defrosted and working again!"
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
SOURCE: Our E522B Fisher & Paykel fridge is less than
Try the video on the F&&P icemaker it will walk you thru diagnosing the problem. www.appliancehelponline.com/servicemanual.html
SOURCE: Hi, I have a fisher
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
