Question about Kodak Cameras
Kodak z1015is wherever to get cable to charges battery and same in out
Does the usb cable for the Kodak m341 camera charge the battery too
Yes, assuming the USB port puts out enough current to charge the battery. Not all computer USB ports do so. Do not connect the camera through a hub, but directly to the computer.
Nov 28, 2010 | Kodak Cameras
How to charge kodak c142? is the data cable which is used for copy the pictures to the PC also charge batteries?
I don't believe these batteries with this camera are rechargable. the spec sheet calls for alkaline batteries. Do the batteries in the camera say rechargable on them. There is a Kodak battery charger with batteries , but that is a multipurpose charger for many cameras, and all it does is charg batteries like any other batter charger.
Nov 27, 2010 | Kodak EasyShare C142 Digital Camera
My kodak easyshare M320 isn't charging with the USB cord and my camera won't turn on either because there's literally zero battery left.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 28, 2010 | Kodak EasyShare M320 Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
Kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Nov 17, 2009 | Kodak EasyShare C315 Digital Camera
HAVE A KODAK 8.1 MODEL M893 CHARGE IT WHEB YOU TURN ON IT'S ON YOU GO TO TAKE PICTURE IT SHUTS OFF
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 | Cameras
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from camera. If not could you tell me the serial number of each cable. Also would a universal USB cable be...
Yes, you can use the USB cable to charge the battery. But you need to insert the cable into the computer USB port, no the USB HUB, and the computer is on, not in sleep mode.
Jul 01, 2009 | Kodak EasyShare M853 Digital Camera
Kodak EasyShare One lens won't open - camera cycles on/off
I had the same problem. Even though I was keeping the camera on the dock all of the time to charge it, the solution was very simple - get a new battery for inside the camera.
I bought new ones at a greatly reduced price on eBay. Now I carry one with me wherever I go in case the battery wears out/down.
I shoot a lot of videos, so it really takes a lot out of the batteries.
Dec 15, 2008 | Kodak EasyShare One Digital Camera
Cameras Logo
37 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
