Hi!
Contact Peavey Support peavey com Peavey com
SOURCE: Need Fender Squier Bullet 1 w/3 pickups, 1 vol, 1 tone wire diag
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
SOURCE: hello,i need to repair a yamaha 5 string bass
Find appropriate diagram at this site:
http://www.guitarelectronics.com/category/wiringresources/
SOURCE: I need a wiring diagram for a dean v bass (ev or
Match your resources of your guitar at this site to find typical schematic:
http://www.guitarelectronics.com/c=t6JiCQzmaFtGBjJUnATWv1XQ2/category/wiring_resources_guitar_wiring_diagrams/
SOURCE: I'm trying to wire passive
If you have a metal bridge, then install a jumper from a convenient point to the rest of the grounds. These grounds help reduce hum pickup. If the guitar is working with no hum while using and handling it, don't sweat grounding the bridge... The purpose is REALLY to ground the strings which is where you will likely pick up hum when you touch them... you are an "antenna" picking up the noise from all the power lines, etc around you.
