SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
SOURCE: AEG single oven - clock runs for 12 hrs , buzzes
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
