Question about LG Televison & Video
The right half of my LG led tv screen is dark. Is it likely the led panel?
LG 65UH5500 - Have backlights. Not in demo mode. Picture is clear just dark. Vertical, not horizontal.
    Habit-Forming:
    New Friend:
  • 157 Answers
No, it's not the LED strips, You have a T-com board problem, so replace the T-com board.
Posted on Jul 11, 2019
6ya staff
SOURCE:
Kindofcheap
Jayson Brollini
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
Paul
  • 381 Answers
SOURCE: Green vertical bar on right side of plasma TV screen
You could have one of three problems. One is really expensing to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went back. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
Posted on May 27, 2009
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Posted on Jul 04, 2009
Anonymous
SOURCE: LG Computer Half Light, Half dark?!?!!?
Install the forteManager software that comes with your LG LCD monitor. Go to the Options tab and choose Restore which will set it back to factory settings. For some reason some monitors come this way out of the box and this was the only way I was able to solve the problem with mine.
Posted on Jan 06, 2010
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Posted on Oct 16, 2010
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
How to fix an lg 47LE5400 tv power lights come on but no picture
If it's a led tv and if you have sound and, also, if you can see the picture with a flashlight very near on the screen in the dark, that means your backlight or your inverter circuit that control the backlight are defect. Good luck,
Serge.
May 06, 2016 | LG Televison & Video
I have no light on my led tv
The most likely problem is the Backlight Inverter. It supplies the power to the LED array which illuminates the screen. If you are brave and also technically able, it can be replaced at home. Here is a video to help. LCD TV Repair Tutorial How to Replace the Backlight Inverter Board in LG...
Oct 27, 2015 | LG 50" 5400 Series LED HDTV - 50LN5400
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
Sep 28, 2015 | Samsung Televison & Video
What is the likely cause of the left half of a led tv being dark compared to the right half? The pictures is there but it seems the backlight has gone out.
Hi Mike,
It has to be the backlight then. It can be repaired, but opening the LED panel is quite tricky and risky job.
Good Luck.
May 28, 2015 | Televison & Video
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
Apr 27, 2015 | LG Televison & Video
How do I know if my backlight on my LG tv is working
Wait until it is very dark. All lights out. Switch on. The screen should perceptibly change from black to dark grey. Perhaps you will see some light leakage near the edges where glass meets plinth.
And there is the T test where you touch the screen with the back of your hand after it's been on for a while. Although LED backlights are cold, they do generate some heat. So a perceptible change in temperature usually indicates that the backlight is functional.
Oct 06, 2014 | LG 47" 5400 Series LED HDTV - 47LN5400
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
Televison & Video Logo
175 people viewed this question
Ekse
RONALD CARTER JR
