Refrigerators Logo
d
david c Farley Posted on Feb 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I BOUGHT A NEW FRIGIDAIRE MODEL LFSS2612 A MONTH AGO AND THE LIGHT FOR THE TEMPERATURE KEEPS BLINKING H THEN ONE WE WERE TOLD TO LET IT SET FOR 24 HOURS BEFORE SETTING
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
  • Posted on Feb 14, 2019
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017830
Points
74913
Take it back as defective
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on Apr 08, 2007
SOURCE: luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
mortworker
  • Posted on Jun 15, 2008
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Anonymous
  • 22 Answers
  • Posted on Jan 02, 2009
SOURCE: cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 18, 2009
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Anonymous
  • 3 Answers
  • Posted on Apr 01, 2009
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Does the green light on my freezer need to be on at all times and temp set to normal
Good Afternoon Friend,
I understand that you want to know if the green light has to be on at all times and the temperature set to normal on your Frigidaire freezer, model# FFU2124D. The green light will always be on. This is letting you know that there is power going to your freezer. You do not have to leave to temperatures set on normal. You are able to choose any temperature that works for you and keeps your food frozen. When changing temperature settings, turn the knob slightly in the direction you want, and wait 24 hours for temperatures to stabilize. If you want to change the temperatures more, again wait another 24 hours after changing them, for the temperature to stabilize. Hope this is helpful.
-Best Regards-
WP
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
5helpful
Dishwasher, flashing lights, frigidaire
Power light just keeps blinking and T V will not turn on
Purchased just a month ago? It should still be covered by the manufacturer's warranty. Unless the seller isn't a legitimate retailer. Try warranty repair before worrying about fixing it yourself.
Frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
3answers
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
