Hello, obviously your Sony GNV111D, does not work due to problems in the outputs or the power supply
If you have technical knowledge, I will send you the link of the service manual, if not, take it to a specialized technical service
I hope you can enjoy your Sony as soon as possible
Greetings Franco Dosil
Hola, evidentemente tu Sony GNV111D, no funciona por problemas en las salidas o la fuente de alimentacion
Si tienes conocimientos tecnicos, te envio el link del manual de servicio, sino, llevalo a un servicio tecnico especializado
Espero que puedas disfrutar de tu Sony lo antes posible
Saludos Franco Dosil
https://www.manualslib.com/products/Sony-Hcd-Gnv111d-3771741.html
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
SOURCE: Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
SOURCE: Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
SOURCE: bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I
didn't have to mess with universal remote control codes or anything.
Hope that helps.
