SOURCE: Google Chrome removal
right click on any internet shortcut icon -> select properties and to the right of where it says Opens with: click "Change"
Now you'll be given a list of recommended applications
If you were using firefox it will probably be right there just click it then click "ok"
if the application you used before isn't there click "Browse"
If you want to use Internet Explorer just go to: My Computer -> C:\
-> Program Files then find the folder called Internet explorer, inside you'll find iexplore click it then click open
let me know if that worked ok for you
SOURCE: I removed Google Chrome and
1. Go on start menu and find "control panel"
2. Once you've clicked on "control panel" click on "network and internet"
3. Click on "programs"
4. Click on "make default"
Hope I helped
Dr Reed
SOURCE: uninstalling google chrome
Agree google chrome is no good
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have if don't need any of them you can disable or remove them
http://download.cnet.com/mozilla-firefox/3000-2356_4-10208565.html Surf the Web comfortably, relying on speed, safety, and power of customization.
Use firefox this is less intrusive and takes you exactly where you want to go without any side steps you can still use google as you homepage
