SOURCE: Grip pen not responding
You could try recalibrating the tablet. Open the tablet control panel, then click "About." Then hold Control while clicking "Diagnose..." and on the next screen -- the Diagnostics window -- you'll see a new button labled "Recalibrate..." Clicking that might do the trick.
Good luck.
SOURCE: proform vr900 recumbent tension not working
Here is a link to the owners manual. If this is correct the fix should be relatively easy
http://www.iconservice.com/pdf/PFCCEX01010.pdf
Gerritt
Serving the Twin Cities
SOURCE: i need a manual on my stamina r360 recumbent bike
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
SOURCE: PTS Turbo 1000 Recumbent Exercise bike
go to airfreetires.com and buy 27 x 1 1/4 Nu teck Savannah Cruiser (17-18)(630). cost 34 bucks plus s& h. there is info on that site about supplying 500 of these tires in the last 11 years to replace tires on this bike. they also speak incredibly highly of this bike as well. read blog. very interesting. this is a cult bike.
Testimonial: "PERFECT! This response is exactly what iI have been looking for. Many, many thanks."
It is very difficult because there are two main
versions of exercise bikes, so I've picket two of each type. If you prefer an
upright bike the Schwinn 140 Upright Bike is the best pick, if you're more into
recumbent bikes the best option is Nautilus R514 Recumbent Bike, both of them won
the 2011 best exercise bikes.
