A blocked exhaust vent is the most common reason the air overheats. When the thermal fuse is blown in an electric dryer, the controls light up but the drive motorwon't run. You can't reset the thermal fuse; if it's blown, you have to replace it with a manufacturer-approved replacement part. ... Unplug the dryer.
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
SOURCE: Hi - We have a KitchenAid
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: i got pulled over for
More than likely the bulb is burnt out. If it was a fuse alot more then the tag light would be out. The bulb is pretty simple to change depending on what model ford you have. Usually its 2 screws or it pops out.
SOURCE: model gew9250. Dryer will not
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
