Question about Sansui Televison & Video
Sansui tv won't turn on - Sansui Televison & Video
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Feb 02, 2013 | Sansui HDLCD3250 32 in. LCD TV
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Sansui TV won`t turn on and makes a continuous clicking noise and small flashing in center of screen
There is shorted component/s in the horizontal output circuit of your set. Check and replace them.
Aug 04, 2012 | Televison & Video
My sansui television fell off my tv stand, it dropped about a 1ft to 1.5ft on the glass front but didn't break, sounds like it turns on but no picture, do you think its fixable?
You need to give it a shake and see if you hear anything loose.
respond with how this turned out.
Assuming its a CRT, something heave ripped away from the board on impact.
or the nack board on the back broke the tube.
the first situation is fixable, the second is not.
If its a small TV you should forget about it, the charge to fix it won't be worth it.
If you got a techie friend, you got a good chance.
PLEASE RATE THIS ANSWER
Aug 15, 2011 | Sansui Televison & Video
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
Trying to program my sansui tv with the cablevision remote control. unable to find codes
You have to do the universal way which involves:
1) turn on tv and dvr
2) press tv button + select, hold till the io button stays lit (5seconds)
3) once io button is lit, press up and down channel buttons and flip through them until the tv turns off.
4) press mute, this should turn the tv on.
5) press tv button to save the settings (turn off tv)
Oct 05, 2009 | Sansui DTV2760 27" TV
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
