Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
