Question about Ricoh Aficio GX E3300N InkJet Printer
I have 3 pcs printers Ricoh GX E3300n. All of them has an Error code ERR 975. Can't find any information about this error.
6ya staff
SOURCE:
Anonymous
  • 417 Answers
SOURCE: cause for error code sc560 on ricoh ap3850c
H there below is what is stated in the service manual and I suggest to change the power cord before the main PSU (Power Supply Unit)
SC 560 Zero Cross Error
When the power switch is turned on. The machine checks how many Zero-cross signals are generated during 500 ms. If the number of Zero-cross signals is more than 66 or less than 45 and the condition is detected more than 10 times this code is shown.
Cause is electrical noise in the supply from the power cord.
Solution
  • Change to another power wall socket
  • Change power cord
  • Replace main PSU (Power Supply Unit)
I hope this help you
Thanks J
Posted on Jan 13, 2008
Anonymous
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
Anonymous
SOURCE: have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Posted on Apr 24, 2009
quennie732
  • 422 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
Rich Aficio GX e3300n ink smears on every print. I have cleaned and flushed heads. Still have the same problem.
Contact Ricoh and talk to the tech support guys. The print heads are shot. They might send you a replacement printer and have you return that one in exchange.
Oct 30, 2013 | Ricoh Aficio GX E3300N InkJet Printer
Printer turned off and will not turn back on,
Try unplugging it and plugging it back in, then see what happens.
Mar 23, 2013 | Ricoh Aficio GX E3300N InkJet Printer
Try unplugging it, waiting a minute, and plug it back in.
Ricoh gx3300n Blinks lights on start but fails to power
Your printer is fried but i bet you figured that out by now. You using Saw grass ink i bet. Well thanks to them you now have boat anchor. The ink destroys the printer. I got one 2.
Aug 25, 2012 | Ricoh Aficio GX E3300N InkJet Printer
Error msg says indepdnt.ink set and my yellow is full but shows empty. I am using sublimation cartridges, refillable. other 3 colors are fine
it sound like a faulty chip on the cartridge, you could try cleaning the contacts on both the cartridge and the printer to see if that helps but personally I think it will be the chip. new cartridge or chip im afraid. I could have helped you more if you had included in your question the make of printer etc.
Oct 06, 2011 | Ricoh Aficio GX E3300N InkJet Printer
Its telling me theres a jam but there isnt
than you have to check inside ..for the paper sensor ..and see whats wrong with it ...reset the printer ..and will work ...When you open it up look for paper leftovers and other things that my obstruct it ..or it is not well aligned..
May 28, 2010 | Ricoh Aficio GX E3300N InkJet Printer
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio GX E3300N InkJet Printer Logo
97 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
