Question about Sansui Televison & Video
I lost my remote and im stuck on run channel auto scan on SANSUI SLED tv
I was trying to turn up the volume on my tv before going to bed because i lost my remote and i clicked the wrong button and i dont know how to fix it
Anonymous
SOURCE:
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Posted on Oct 27, 2008
Anonymous
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
coyotedave
  • 280 Answers
SOURCE: cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Posted on May 01, 2009
Jim Krause
  • 1779 Answers
SOURCE: TV won't stop changing channels
Main board needs replaced !
Posted on Jul 03, 2009
NicK Hale
  • 12 Answers
SOURCE: Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Posted on Oct 07, 2012
Samsung le40b530
Chances are that one of the volume buttons (either on the TV itself or on the remote) is stuck. You'll be able to know if it's the remote by taking out its batteries and trying the same process. If the issue persists, see if the volume down button on the TV is stuck and can be freed.
Dec 18, 2013 | RCA Audio Players & Recorders
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the Television On.
2. Press and hold the TV Power button for three seconds until the LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
Apr 16, 2011 | DISH Network IR Remote Control
My HDTV, 42", won't turn off, change
Check the tv manual control buttons right side of the tv bazel frame tv facing u,see if u can used the buttons like power, chanels - + or volumes - + from it.If u can, mean the tv have problems with is remote control.Change new batteries for the remote,still no response from the remote.Mean the remote is dead.Try website like Remotes.com to buy an exact remote or very close it.
Jan 17, 2011 | Sylvania LC420SS8 LCD TV
I have a at&t uverse remote and am trying to program it to my emerson tv,but i dont have the codes
Go to their website to find out a download copy of the codes if not just buy a new one.
Jun 29, 2010 | Televison & Video
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Mike
Jul 04, 2008 | Televison & Video
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Magnavox mptv68a
Hello pea16 serrure enfants means lock infants or as we say child lock.
Hold the display button down for 10 seconds, which removes the lock.
If that does not work try: unplugging the TV for about five minutes and see if that clears it, If you need the owner's manual you can goto: http://www.magnavox.com/ then click on support center and enter your model number.
Then go to the language section and select english.
I hope this helps,
Thank you,
Shuttle83
Dec 22, 2007 | Televison & Video
ESA TV
My screen shows only about 2 inches of picture, horizontally across the center of the TV
Sep 11, 2007 | ESA ET427E 27" TV
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
