Use the below method with caution because it wipe all of your data
1. Turn Off Your Device. if the device is freezing Remove Battery and insert few second.
2. Press and hold Left key + Right Key Together Press Power Buttonuntil vibrates.
3. Now select "factory reset (full wipe)"
4. then select "Yes"
wait for few seconds
5. after finish Hard Reset Select Reboot System Now
Your Device will be auto restart
Done.
SOURCE: How to hard reset a Sony Ericsson K810i ?
your fone default code is 0000, go in setting then slect restore setting or factory setting and enter code 0000.
SOURCE: i need an unlocking code
http://www.wickedunlock.com/ provides you with unlock codes when u submit your IMEI number
