Hello Jeffrey, the integrated power circuit that your SA-WMS230 subwoofer uses is the TDA7294
I attached the link to download the service manual for your Sony
I hope you can solve your concern
Greetings Franco Dosil
Hola Jeffrey, el circuito integrado de potencia que utiliza tu subwoofer SA-WMS230 es el TDA7294
Te adjunto el link para que descargues el manual de servicio de tu Sony
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/39/3893/389216-sony/ssv230.pdf?ce26e2f20d1410c991e4cc27a56c5d81&take=binary
SOURCE: puk code is rong so that i need right puk code
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
SOURCE: panasonic sa-vk950 ;the psu 8 pin ic is blown
Did you try iFixit? they have lots of mainenance manuals and video's from electronic equipent.
SOURCE: need manual for sony SA-WMS230
If the manual is removed from the official site as is sometimes the case, here's an alternative link:
Sony SA W2500 manual
The number is on top of the ic. Open unit up and read the info off of it.
