Question about Kyocera Office Equipment & Supplies
My kyocera DC 6240 photocopier is showing me refill or replace toner kit even after i have refill it keeps on showing me same thing
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
You must use OEM toner if you use aftermarket toner that says for use in you will get this problem if you have been using aftermarket toner you will have to change developer or empty all toner from developer unit and start with OEM toner Kyocera stamps their logo into cartridge
Posted on Mar 20, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Ho to refill Cannon Imageclass X25 toner?
You're only asking for problems trying to do it yourself. It' extremely messy, and more involved than simply adding new toner. and the refill kits are a scam. Find a reliable supplier, and get a remanufactured unit with a guarantee, if you're looking to save money. Cartridges are designed to go 1 cycle, and then require a new drum, cleaning blade, doctor blade, bushings, toner, etc. The cartridge includes not only the toner supply unit, but also a waste section, that, even if you were to refill somewhat successfully, the section will begin to overflow, causing further problems. Cut your losses.
If you're local. I can help:
http://www.hotfrog.ca/Companies/Sandman-Sales-Service
Posted on Feb 16, 2009
Mike
  • 167 Answers
SOURCE: j-11
J11 is telling you that the copy paper has not fed from the 1st paper cassette under the machine.This may be due to incorrectly loaded paper,cassette requires adjusting or the feed roller requires cleaning.The feed roller sits in the machine and you will need to unplug the copier and remove the paper cassette to gain access,Clean the roller with lint free rag and spray and wipe.
Posted on Oct 12, 2009
Jonnhzz Chan
  • 186 Answers
SOURCE: Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Posted on Feb 18, 2010
rajeshv95
SOURCE: samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
Posted on May 03, 2010
Printtech
LXK Chris
  • 1087 Answers
SOURCE: Replaced toner and maintenance kit -keep getting
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Posted on Jul 29, 2010
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Can I use Kyocera toner for utax Copy machine?
take the cartridge along to a ink refiller shop and ask them as they have a good knowledge of product inchangeability
Aug 12, 2016 | Kyocera Office Equipment & Supplies
I want to refill kyocera mita dcc 2725 with fs c5400 refill toner. will it work
NO do not mix different types to toner. Major mistake that will cause the developer to go bad and even can cause fuser problems. toners are not the same. The have different percentages of ingredients depending upon the melt point of the fuser and the image density of the device.
Printer Repair Service in Miami and Fort Lauderdale FL
Feb 02, 2016 | Kyocera Office Equipment & Supplies
Image cycle
if you use toner that says for use in instead of Kyocera brand toner this can happen you have to remove all the toner in the dv unit and install only Kyocera toner when you do that enter 1087 1087 then 130 and let it run until its done this will refill the dv unit with toner even though you have a copystar machine its made by Kyocera when it stops enter 01 then print to return to normal operating mode
May 07, 2014 | Copystar - CS-3035 Printer
Kyocera Mita Photocopier KM-1530 Error code AP flashes at start up then C710
When AP flashes the toner is being replenished inside the copier. Wait a few minutes. You need to refill the toner.
Jun 09, 2011 | Office Equipment & Supplies
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
Replace Toner
Remove, shake well and re-install. It may have a broken auger inside the cart.
Feb 10, 2009 | Kyocera FS-9520DN Laser Printer
Open Questions:
51 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
