My Frigidaire side by side reads 56 what do I do
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
SOURCE: Samsung side-by-side refrig is not staying cold
Look for signs of frost build up on back freezer panel. If there is build up then it has a defrost problem. I haven't had much experience with samsung but I beleive it has a fuse in the defrost circuit on the evaporator and that may be the defrost problem.
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
SOURCE: model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
SOURCE: Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Good Morning friend, thanks for your post!
From what you have described you unplugged your Frigidaire refrigerator to clean it and now it is not cooling. You could have a possible short within the control panel or wiring harness. I would recommend performing a reset on your refrigerator and you can do that by disconnecting the power for at least ten minutes.
If that does not jump start your compressor you may want to make sure it is not in demo mode or the control is locked you should be able to notice any error codes on the panel. If you need additional help I would recommend contacting a professional technician for proper diagnosis and repair. -Matt
Good Morning friend, thank you for your post!
I see that your Frigidaire refrigerator is displaying an "OP" error code and you want to know what it means. An "OP" could stand for open thermistor. This could be a possible problem with your thermistor or control panel. In any case that it is a false error code I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for roughly ten minutes. If that does not help resolve your issue I would suggest consulting with a professional technician for proper diagnosis. Hopefully this is helpful information. -Matt
