SOURCE: Dyson DC07 works and cleans fine, but motor makes loud screaching sound.
If the screeching noise is happening at all times, it is most likely a motor failure; which unfortunately can only be resolved by complete replacement of the motor.
If it's a loud ratchety-screeching type sound, and is only occurring when the brush is set to carpet, it is most likely due to an obstruction of the brushroll or a problem with the clutch. Ensure that the brushroll can spin free, look for anything physically blocking it. Check the bearing ends on the brushroll, they can melt and cause the brushroll to not spin effectively. If neither of those two things resolves the problem, the clutch most likely needs replacement.
-R
SOURCE: my dyson dc 16 hand held vacume stops & starts
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
SOURCE: I have a dyson hand held that shuts off after just
yeap..... i just found a fix for this ,, its mad how easy it is to fix as well...and it works 100%,,,
now dyson implemented a filter magnetic switch if u take your filter off you will see a small magnet in the corner,, u will notice where the magnet is behind it is rased platic,, now,,that the problem on the main board the transistor that picks up magentic signal from the filter is dud,!
dont ask me why it happens,, its a pain i know.,.
now take off collection pot for dust now take battery off.
now where the serial number is theres 2 hex screws that need taking out..
now u will see a small pcb board.. remove with one tiny security screw holding it in,, once removed pull both red plug off thats the digital motor plug.. and white plug which is vcc..to battery,, once u have done this pull the board down and back gently. as there is a long bit of board that goes up the back of the dyson plastic be very carefull pull this out.. now the long and thin pcb board that is hidden is what we need there is a tiny transistor,,, we need to remove this carefully..once removed,, we solder a thin wire from 2 point A+C need to be soldered together with a thin piece of wire, it will not harm the motor.. as long as u keep it clean,,
these points corolate to the transistor,,
A
B C
SOLDER AND A+C WITH A FINE PIECE OF WIRE NOW,, AND WALLAH... fixed put it all back together again,,, charge the battery,, and your away,,, working again,, if not u have other faults.. but 99% fix this with flashing red led,,,!!
SOURCE: how to replace motor on Dyson DC08 vac
I have made a video showing how to replace the motor on a Dyson DC08. If you follow the instructions you should be able to do it. If you find the video helpful please give me a thumbs up or a comment.
If you find you need parts for this procedure I would recommend Vacuumspot or Nelson Vacuums
Dont forget to let me know how you go!.
SOURCE: how do i hang dyson hand vac on wall
click on the link below for the manual it will give you full instruction how to fix to wall, enjoy,,,
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc16_manual_uk.pdf
