It's not a 9. it's a "g". Means you have a clog in the hose. I JUST re-read the book and it dawned on me. I went to check the hose and low and behold I found a bag in the vent!
Have you possibly activated the child lock? See below instructions on how to turn it off:
Child Lock
Child Lock prevents children from playing with the dryer.
When Child Lock is activated, all buttons except for the Power button are disabled. To activate/deactivate Child Lock, simultaneously press and hold Temp. and Time for 3 seconds.
NOTE
If Child Lock is activated, and the dryer is turned off and then on again, Child Lock remains activated.
I can't find anything online about error code CL9. Even the owner's manual does not list that error code.
https://www.searspartsdirect.com/partsdirect/user-manuals/dv48j7700ewa202-samsung-parts-manual
Probably call a repairman Unless you know how to diagnose the problem. There are several possibilities that could cause a dryer not to heat. Improper voltage, inadequate ventilation, heating element, thermostats / fuses, timer, or motor.
